XF (X260) 2015 onwards
P2098
Old Aug 8, 2017 | 10:33 AM
09XFwhippin's Avatar
Default P2098
I received the following code the other day p2098.
P2098 is an OBD-II generic code for the engine control module (ECM) detecting the post catalyst O2 sensor fuel trim is testing too lean on a two trip minimum to set the code.
I replaced my cats and O2 sensors 5 months ago, highly doubt they are the problem. Can someone provide me any information on what specs the sensors should be reading at or anything that may help diagnose the issue.
thanks.
Old Aug 8, 2017 | 01:05 PM
Your forum user name suggests you have a 2009 XF (X250), not a 2015 onwards X260?
