XF (X260) 2015 onwards
Retro fit ACC on a x260 XF
Old Sep 8, 2021 | 01:34 PM
bohdanf01's Avatar
Default Retro fit ACC on a x260 XF
Hi, newbie member and yes, I have seen some info on possibly upgrading the cruise control on my ‘65 plate XF (x260).
i thought I would do this, if possible and does not cost the earth, but now I am reading that in fact ACC may not be all that good in some situations. Standard CC is better. How true is that?
is it worth the cost to upgrade to CC? My reason for pondering this is fact that with CC you have to intervene a lot, then we-engage the CC. I am now seeing posts that describe ACC getting real close, breaking hard, accelerating up again. True?
i do not want to spend the money if I end up not liking ACC. Better to stick to standard CC.
as I am not very mechanical minded I would have to find a an independent specialist to do the retro fit.
Old Sep 10, 2021 | 01:17 PM
2018XF25T's Avatar
Though 2 of my vehicles comes equipped with CC I simply never used it or will I ever be. The answer to that is, it will make me feel sleepy driving on the road if I rely on CC. There are a lot of YouTube videos regarding about the advantages & disadvantages of ACC over CC. I think in you case, once you have the ACC, you'll never go back to CC. Just my take.
Old Sep 10, 2021 | 04:46 PM
MoJo88's Avatar
You have the ability to set how much distance you want to leave between you and the car in front of you when you are in follow mode. Once it's senses that there is a vehicle ahead, it eases off the throttle and starts braking. So I can't see how it would get real close and then brake hard unless the had it in the most aggressive mode.
Old Sep 11, 2021 | 02:43 PM
bohdanf01's Avatar
Hi 2018XF25T, from my point of view I have never had a car with something like CC. Just a few weeks ago I had to hire a car for the family holiday, which came with (standard) CC and I loved using it, guess the novelty factor. But I see your point of view about becoming lazy!
What make it difficult for me to decide is that it is not a clear cut decision one way or the other, opinions seem to be evenly split. It would be good if the system would allow you to switch between CC and ACC, like I have the option of standard speed limiter or intelligent mode.
Old Sep 11, 2021 | 02:45 PM
bohdanf01's Avatar
Hi MoJo88, that’s what I thought/understood, but I have read some reviews complaining of getting close then breaking hard. Confused me somewhat.
Old Sep 11, 2021 | 07:39 PM
Colin G Kennedy's Avatar
I have ACC in my X260 Sportbrake and I very rarely drive without using it, it has always performed flawlessly.
I would recommend it without hesitation.
Old Sep 12, 2021 | 07:08 AM
SCMike's Avatar
I agree 1000%. Had the 2020 XF-S out on a recent road trip with a couple of solid 8-hour days behind the wheel on interstate highways, repeatedly going from 70+ mph (wink-wink, nudge-nudge), down to a crawl, back up to speed, down to a crawl…. The ACC performed flawlessly, and took much of the tension out of the drive (auto pacing the car in front at a safe distance set by me). Has become my car’s favorite feature.
Old Sep 16, 2021 | 06:22 AM
0n0t0le's Avatar
I istalled ACC to my x260 myself and it is great mod. I already did it on my previously x250. If you often drives on highways you will be very happy with ACC.
Old Sep 16, 2021 | 06:25 AM
bohdanf01's Avatar
hi, interesting. I took my car to a local “specialist” who basically said not worth the effort, too expensive.
may I ask how did you do this? As I say, I admit I am not very mechanically minded - certainly not to tinker on my car. How easy was it? What are the steps? Parts?
Old Sep 16, 2021 | 10:36 AM
0n0t0le's Avatar
you need:
abs pump with acc support
radar unit
radar unit cradle
radiator grill with radar cover
new right buttons in steering wheel.
all wirings exists. Just plug and activate it in car config.
Old Sep 16, 2021 | 11:10 AM
bohdanf01's Avatar
you need:
radar unit
radar unit cradle
Sorry, but I am new to this forum, and never had a Jag before hence am uncertain, did you source the parts from Jaguar (expensive), or an alternative (cheaper) source? Can you recommend a site for Jag spares, that are trust worthy?
You say that all wirings exist already, which is good.
thanks
Old Sep 16, 2021 | 04:54 PM
0n0t0le's Avatar
thanks
Buttons, cradle and grill with cover i got new from dealer. Abs and radar - used from ebay.
Old Sep 17, 2021 | 10:02 AM
MoJo88's Avatar
I often find this to be the case when the company/individual simply doesn't know how to carry out the retrofit and they fob it off as either being too expensive or says something like "it's physically impossible".
Old Sep 18, 2021 | 04:54 AM
bohdanf01's Avatar
yes, indeed. Doesn’t just apply to cars but to other trades as well. Why can’t people just be honest and say “ never done this , don’t know how to do it…”
Old Sep 18, 2021 | 04:57 AM
bohdanf01's Avatar
I face the problem that even though I can source the components I don’t think I am capable of retro fitting ACC.
We still can only assume that like your car my 2016 x260 model has the wiring in place.
Old Sep 18, 2021 | 11:02 AM
MoJo88's Avatar
You can contact me for this retrofit service if need be.
Old Sep 23, 2021 | 06:44 PM
bohdanf01's Avatar
hi, sorry for not replying sooner. Thanks I may just do that.
Old May 23, 2022 | 04:21 AM
Smaug's Avatar
Hi, raising this from the grave again, do you still do a ACC retrofit for UK jag x260’s?
Old May 23, 2022 | 08:09 AM
MoJo88's Avatar
Yes.
Old Apr 21, 2023 | 04:52 PM
celtic_pt's Avatar
Hello,
From Portugal it is difficult to go to retrofit. Could you please state part numbers involved in this retrofit in order to estimate real cost?
Regards
