XF (X260) 2015 onwards
Rusted Ground Connectors
Old Aug 7, 2024 | 09:28 AM
lesjones66's Avatar
Question Rusted Ground Connectors
I have been having issues with the HVAC for about 3 years now. Replaced blower motor and resister 3 times since then. Finally raised hell with the dealership to get them to look further back than those items - spoke with the shop forman and he agreed to look at it with his tech. Turns out, there was a leak from the sunroof in 2019 that caused the ground wire for these components to rust and fail, thus causing the HVAC system to no longer work. He made mention that other ground studs were "questionable" but of course didn't tell me which ones. Does anyone know what other grounds exist under the driver-side seat that he could be referring to? Asking because I have a few other intermittent codes that I'd like to see if they are related (one of which was the heating in the seats).
Old Aug 9, 2024 | 06:21 AM
lesjones66's Avatar
Default Rusted Griund Connectors
Originally Posted by watsondon
Under the driver’s seat, you should check a few things. Look for the ground connections related to the seat heater, the body ground points where the seat bolts to the floor, and any electronic ground wires for the car’s electronics. Also, check the ground connections for power-adjustable seats if you have them. Make sure there’s no rust or loose wires. If you're unsure about inspecting these, a mechanic can help you out.
Thanks for your response. I saw an intermittent code on the seat heater, so I’m betting that’s the cause. Is there a ground under either seat for the air bags or any other electronics? The light for that comes on occasionally as well. It’s been looked at by the dealer several times - stays off for a while then comes right back on. I’m trying to determine how many new bolts I need to pick up before I start breaking things down so that I can do it once and be done.
zaphod beeblebrox
Jun 28, 2022 03:06 AM
worzella
May 19, 2020 09:13 PM
Doug
General Tech Help
May 21, 2014 05:24 AM
Chris Craddock
Jun 23, 2013 09:20 AM
97x306
Dec 24, 2011 12:48 AM
