XF (X260) 2015 onwards
Small battery
Old May 13, 2022 | 11:46 AM
kirkinmich's Avatar
Default Small battery
I have a 2015 xf 3.0 supercharged. Just had is dealer for service and was told the small battery was weak. $500.00 for replacing. I have read you can unhook and it will disable start and stop at lights etc. I would be happy to have this stop but what other problem will this cause? Any help would be appreciated. Thanks kirk
Old May 13, 2022 | 07:35 PM
mleskovar's Avatar
Wrong forum ......... you want X250 forum. Just guessing the only problem this would cause is a message saying SS is inoperative/off?
Old May 13, 2022 | 08:15 PM
OzXFR's Avatar
Zero problems with disabling the SS system on the F-Type, heaps of us have done so, on both the earlier F-Type with the two battery system (2013 - 2015) or the later F-Type with the single battery (2016 - )
For the earlier F-Type just unbolt the end of the black cable which runs from the negative terminal of the secondary battery from where it bolts to the floor of the trunk/boot, or you can even remove the secondary battery altogether. I ran with the unbolted cable for a few years then about two years ago I removed the battery, zero problems in both cases and zero effect on anything else.
It should work the same in a 2015 XF.
If you want a new secondary battery it is an Exide EK151, hard to find but much much cheaper than a dealer supplied replacement.
scotsgeeza
Dec 22, 2020 07:12 AM
James Ambrose
Mar 10, 2020 11:03 PM
Paul champagne
Feb 15, 2020 10:03 PM
spanky145
Feb 2, 2019 04:56 PM
clubairth1
Apr 18, 2018 09:18 AM
