XF (X260) 2015 onwards
Standby relays.
Old Jul 20, 2025 | 01:44 PM
Tomek_krot's Avatar
Default Standby relays.
Hello everyone. Patient: x260 Sportbrake 2018r.
B1412-96 Standby relay box - internal component failure. In the trunk on the right side is the fuse and relay module JX63-14N030-AB. Which relays are responsible for this error? Should I replace all the ones I've marked in red? Regards
Old Jul 25, 2025 | 10:06 PM
Lightweight's Avatar
Are there symptoms to the problem or was this found on a scan? I don't know this error but before firing the parts cannon at it I would start with the basics. What is your battery state, is there a bad ground to the module has the connector to the board corroded or come lose, any sign of water ingress? If there are systems that have failed start with the components for them first. Relays are generally very reliable. From what you have highlighted in red, they look to be on the system board not 'user replaceable' components.
From Land Rover forums there are a few posts on this error code so it may be looking there.
Old Jul 27, 2025 | 02:03 PM
Tomek_krot's Avatar
Hello. The battery is new, the connector is fine. There's no water, it's dry as a can. After scanning, this error appeared. I got error P0039, but I haven't fixed it yet. I'll check the ground. Thanks for the tip.
Old Jul 27, 2025 | 04:36 PM
P0039 is apparently for the supercharger/turbo bypass valve
For the original B1412-96 Standby relay box - internal component failure message there is apparently a TSB that states this is a false positive if no other symptoms show: SSM72302 Jaguar Accessory Control System TSB
No idea if there is a fix, I have not found reference to it.
Old Jul 28, 2025 | 04:59 AM
Tomek_krot's Avatar
Thanks for your help. The only thing left is P0039. Which sensor is responsible for this error? Where can I find it? Best regards and best wishes.
Old Aug 2, 2025 | 10:13 PM
Have you been able to find the sensor? I'm assuming this is for the 3L V6 SC engine as I have no idea on the 2.0 Turbo or diesels. Based on my stripped down intake the relief valve sensor is the top large grey one in the middle front of the supercharger housing. Not the small black circular sensor, I think that is for air temp..
The grey 'goose necked' connector below is what I assume to be the sensor. This is a guess based on where it is though.
Old Aug 3, 2025 | 08:02 AM
Tomek_krot's Avatar
Hi. I found this: error P0039 was generated by the valve that engages the large turbocharger. I have a 2.0-liter 240 hp engine that I've been overhauling for the past four months because the crankshaft was damaged. The previous owner changed the oil every 35,000 kilometers. Your suggestion and the diagnostic program helped me find the problem. Thank you for your help.
PBRStGang
Sep 6, 2025 04:24 PM
car5car
XF (X260)
Apr 27, 2020 10:48 AM
Terrific
Jul 21, 2018 01:56 PM
JensenHealey
Feb 25, 2017 07:20 PM
TinyDancer91991
Jul 31, 2013 04:46 AM
