XF (X260) 2015 onwards
Symposer?
Old Feb 15, 2017 | 10:53 PM
mleskovar's Avatar
Default Symposer?
What does the "symposer" consist of and where is it? "....a carefully tuned symposer feeds some of the supercharged V6’s induction sound back into the cabin to make exploiting the performance potential even more exhilarating...."
Old Feb 16, 2017 | 12:56 AM
jbn's Avatar
jbn
Link: https://www.jaguarforums.com/forum/x...emoval-157665/
Old Feb 17, 2017 | 01:33 PM
mleskovar's Avatar
Thanks for the link. The "speaker/resonator" is obvious on the firewall from inside the engine compartment and easy enough to access. I temporarily pinched off the hose leading to it and yes it reduces the sound. I'm planning to put an inline plug right at the 'resonator' and reconnect the hose so there won't be any vacuum leaks and then I'll test it more thoroughly but I can't imagine why I would ever reconnect it.
Old Feb 17, 2017 | 06:47 PM
mleskovar's Avatar
That was almost too easy. No tools needed. Pinch the connector ring and pull off the hose. Insert plug.... cut from rubber stopper to fit snug without extending too far out.... and push hose back on until it snaps in. Will test when torrential rain stops.
Attached Thumbnails Symposer?-before-after.jpg   Symposer?-snap-ring.jpg   Symposer?-plugged.jpg
Old Feb 18, 2017 | 12:25 PM
mleskovar's Avatar
Works great. Intake sound still there when you give it the juice but much more subtle and in the background.....like it should be IMO.
