XF (X260) 2015 onwards
Where is starter on 2010 XFR?
Old Mar 30, 2022 | 07:46 PM
MikeR397's Avatar
Default Where is starter on 2010 XFR?
I need to replace a starter on my 2010 XFR. It’s supposed to be on passenger side, accessible underneath. Anyone have a diy or at least diagram as to where it’s located?
Old Mar 31, 2022 | 12:54 AM
OzXFR's Avatar
Get yourself a copy of the XFR 2010-11 Workshop Manual from my Dropbox here: https://www.dropbox.com/s/bet26xniua...kshop.pdf?dl=0
Then go to section 303-06C pages 1268 and 1269.
Old Mar 31, 2022 | 04:11 PM
MikeR397's Avatar
Thank you so much!
Old Mar 31, 2022 | 04:57 PM
MikeR397's Avatar
The manual isn't actually helpful in locating it. I think I can see it from the top on passenger side, which is not how my dealer said it's accessed. Will remove the airbox to see if I can get a better look. The dealer quoted me $775 for the part, they won't install a used part, and about $1,000 in labor. Sigh.
Old Mar 31, 2022 | 05:58 PM
This what you are after?
The WorkShop Manual indicates it comes out from below after removal of the air deflector.
Old Mar 31, 2022 | 06:04 PM
MikeR397's Avatar
Yes! Thank you! I found it!
Old Mar 31, 2022 | 07:37 PM
MikeR397's Avatar
Thank you again guys, will throw in a $79 used starter off a 67k mile XJ and this just saved almost $2K at the ***********. Was not that hard at all once I found it, the exception being the 13mm nut by the cat that needs a ratcheting wrench and mine’s sidewall was too thick to get on, but two minutes with an angle grinder fixed that issue!
newfire
Sep 27, 2022 07:12 AM
Ellentoft
Other Areas
Sep 19, 2017 02:08 AM
Mark Bochan
May 24, 2013 10:16 AM
Escolar
Aug 11, 2012 08:17 PM
jaguarevan
Aug 7, 2009 09:00 AM
