XF (X260) 2015 onwards
XF ( Premium- Auto)full shut when slowing down or stopped at lights
Old Aug 31, 2020 | 02:00 PM
Sandyc's Avatar
Default XF ( Premium- Auto)full shut when slowing down or stopped at lights
Hi all,
I am wondering has anyone come across this problem.
My car when stopped at light, junction ect, shuts down completly when I am about to take off.
I've had it at the garage, while it is storing a stop/ Start error ( once), they have not found the cause.
Has anyone any idea or experience with this?
Old Sep 1, 2020 | 02:04 PM
CarsonCitySmith's Avatar
Hi:
Just to clarify your question, are you talking about the automatic feature that kills the motor when you come to a stop? You can disable that feature by pressing the button on your console twice. That's temporary, you can disable the feature totally by disconnecting the power supply to that computer module, up behind the access port on the right side of your trunk's interior. There is a long discussion thread here in the archives on that subject.
Assuming you knew about the automatic feature, your description sounds so much like a malfunction of that feature that I would recommend disabling that computer module just to see what happens.
Good luck, and do report back with your resolution.
P.
Old Sep 1, 2020 | 04:04 PM
Sandyc's Avatar
Originally Posted by CarsonCitySmith
Hi:
P.
Hi P
Thanks for the response,
I have been disabling the feature , initially I thought this was working, but now its happening regardless of being disabled.
When I say full shut down , The vents rotate and close down even in "D", so I have to wait for it to finish powering down to be able to move to "N" & hit the start button.
its very frustrating.
One garage have suggested I may need a complete servicing of the transmission , if I were sure this was the cause I would go ahead - the lack of clarity on the source could send me down expensive rabbit holes.
Thanks again, and when I get there I will post the result in case anyone else needs it.
I will look up the previous threads as well
Old Sep 1, 2020 | 04:11 PM
F1Virginia's Avatar
Hello SandyC..
What is the state of your battery and its age in miles & months?
Which part of Ireland?
Diesel or Petrol?
V6?
Old Sep 1, 2020 | 04:59 PM
Sandyc's Avatar
Originally Posted by F1Virginia
Hello SandyC..
Diesel or Petrol?
V6?
Hi,
Thanks so much for the response,
Car age- Oct 2012, KM- just hit the 200,000KM
Its Diesel , 2.2 litre ,
I am in Munster, regarding the battery, I brought the car in , in 2018, FSH, I I haven't changed the battery since I got it, It was one owner prior and I have the history I could look through and see If there is anything on there?
Do you think this might be the issue?
Thanks again for replying..
Old Sep 1, 2020 | 10:07 PM
F1Virginia's Avatar
You may find more relevant replies in the X250 thread as this is the X260.
But yes...
Aging batteries and modern Jags don't dance well together..
https://www.jaguarforums.com/forum/x...dip-no-235525/
Old Sep 2, 2020 | 04:34 AM
Sandyc's Avatar
But yes...
Thanks so much, I might change the battery anyhow, thank for the advise , & appreciate you taking the time,
Dayzel108
Dec 15, 2023 04:41 PM
raymond 49
XF (X260)
Feb 5, 2018 04:53 PM
andy.buxtonxf
Apr 21, 2016 11:44 AM
wpaulsmith
Feb 12, 2015 05:07 PM
scottyb01
Mar 14, 2012 10:26 AM
