XF (X260) 2015 onwards
XF Rear Diff Limited Slip ?
Old Nov 27, 2022 | 08:14 AM
HermanWiegman's Avatar
Default XF Rear Diff Limited Slip ?
Quick Question for the XF forums...
Did the XF feature a rear Limited Slip Differential (LSD)?
An enquiring mind in the F-Type forums wants to know.
It is difficult to find good used LSD rear diffs from the F-Type S models.
And I don't want to jump up to the electronic rear diff from the V8 models...
The XF rear diff (and F-Pace) looks very similar to that of the F-Type... so perhaps a carrier swap is in order.
Thanks,
Herman
Old Nov 30, 2022 | 05:03 PM
Haltamer's Avatar
I was pondering this exact question:- The 25t Is really missing a LSD and I was wondering if there was a Jaguar parts bin special I could perform, or even an aftermarket unit.
I've dug around but can't find explicit mention of LSD on any of the models here.
Old Dec 1, 2022 | 06:08 AM
@Haltamer
It appears that the XF, F-Pace, and F-Type all share a rear axle design.
Other Jags may have a similar rear axles, but with different mounting points, or different axle flanges.
I just found a used LSD from an F-Type V6 S model, and I will be inspecting and seeing if the LSD carrier inside the axle has a manufacturer code or part number.
We may be able to put together a kit with Carrier, Shims, and Bolts so that more Jag owners can upgrade.
I’ll keep the forums posted.
Herman
Last edited by HermanWiegman; Dec 1, 2022 at 06:10 AM. Reason: Additional info.. tweets to language.
Therock88
Jan 17, 2021 08:39 AM
ifonly
UK & Eire
Sep 24, 2020 05:12 AM
watson6505
Nov 28, 2019 12:03 PM
Paul T
Aug 15, 2019 02:04 PM
sweatyfox
Mar 8, 2013 05:13 AM
