XF (X260) 2015 onwards
XF Sportbrake X260 Inside noise like window open
Old Mar 28, 2021 | 01:47 PM
JV1's Avatar
JV1
Default XF Sportbrake X260 Inside noise like window open
Noticed as I drive about 30, 40 MPH thereabouts that there is a noise in the rear of the car like I've left a window open (but they are all closed). Checked tailgate seal but no sign of damage. Read in another forum tailgates on earlier models were sometimes fitted misaligned but mine is square on. Could it be that I need more sound deadening? Not sure whatelse to check next?
Old Apr 1, 2021 | 12:06 PM
JaguarJack12's Avatar
Just based on my experience... I had a similar wind noise in my Sportbrake. I thought my window was all the way up, but in fact it was not. I'm not sure why it does not go all the way up sometimes, thus create a seal. My solution seems to be rolling all the way down and then back up -- repeatedly pulling up on the switch when it gets to the top. That seems to convince it to slide up that additional fraction of an inch.
Hopefully that works!
Old May 12, 2021 | 03:39 PM
whyhellothere's Avatar
this happens on a 2018 XF too fyi
Old May 13, 2021 | 08:28 AM
jampana's Avatar
Why don't you check the noise with the A/C recirculated air on and off?
MLRjr
Dec 9, 2019 06:41 PM
mekzd
May 1, 2018 05:37 PM
hwoalang
Mar 18, 2016 04:09 PM
hwoalang
XF (X260)
Mar 17, 2016 02:39 PM
GhostriderXKR08
Oct 1, 2008 06:26 PM
