XF (X260) 2015 onwards
XF X260 2.0d Loud tapping noise from Engine
Old Jul 22, 2020 | 01:03 PM
AJ1299's Avatar
Default XF X260 2.0d Loud tapping noise from Engine
Hi all,
My Jag XF X260 2.0d has been making this loud tapping (Please see attached video) knocking noise for a while now. any suggestions on what it could be?
I have had the oil and filter changed also checked the injectors with a long screwdriver and they seem to be firing and working fine. Any ideas or suggestions would be greatly appreciated.
https://vimeo.com/user120062230/revi...156/f9d9096e8e
Thank you all.
Old Jul 22, 2020 | 04:59 PM
Fraser Mitchell's Avatar
Your link doesn't work. What year is the car and how many miles ? Who maintains it and do you personally check the oil level at reasonably frequent intervals ? The service interval on these cars with diesels is far too extended IMHO and an owner really needs to make sure he carries out whatever the Owner Manual recommends for regular checks.
Old Jul 22, 2020 | 05:16 PM
AJ1299's Avatar
Thank you Fraser, it is 2016 and has done just over 100k. I have had it for a year now, it was maintained by Jaguar before me. I had the service done by indi about 6 months ago and changed the oil and filter myself about a week ago.
Unfortunatly,the oil level was not checked for about 6 monghs....
The link seems to be working for me but I have attached a clip with this reply.
Thanks again.
File Type: avi
Old Jul 23, 2020 | 02:57 AM
I beleive there were issues with the timing chain and its tensioners in early engines. Is the noise coming from the rear of the engine ? Noises like this are very hard to determine with diesels as the combustion in the cylinders makes a knock as well. The old diesels were really clattery before the techies got onto it.
Old Jul 23, 2020 | 04:48 AM
AJ1299's Avatar
I think you are probably right. The noise seems to be coming from the rear of the engine as it appears a little stronger at the rear.
Old Oct 27, 2021 | 05:56 AM
Franio's Avatar
Hi,
Did you manage to diagnose the cause of this noise? Mine sounds similar, though not that loud. I have noticed that it is much louder when the D or R mode of the gearbox is engaged.
ionixxx
Sep 18, 2023 04:33 PM
fabfive
Apr 12, 2020 03:52 PM
Jackie1427
XF (X260)
Sep 30, 2019 09:03 PM
Dj5ivestar
Aug 25, 2018 02:27 PM
Geoffc2411
May 24, 2018 09:01 AM
