2.0 Inch exhaust X250 Aj126
Old Dec 26, 2024 | 04:39 AM
stan879's Avatar
Default 2.0 Inch exhaust X250 Aj126
HI
Looking to upgrade the exhaust system, when i came across this kit from top speed pro 1 form NA in TX.
looking for a lesson, reason why this would be of value.
https://au-topspeedauto.glopalstore....tems-w-h-pipe/
Old Dec 29, 2024 | 05:56 PM
Jssaab's Avatar
I bought one of these kits. When it came the tube size was not 2" as advertised. It was 1.8 or some other odd size
That site you linked in is australia.
Here is where you can get it. $799 USD, Steel even if its a bit smaller than 2 inches. ANd they were very nice to deal with
https://shop.redline360.com/products...haust-w-h-pipe
Old Dec 29, 2024 | 06:13 PM
OzXFR's Avatar
Also note that this exhaust system is advertised as being for the XF V6 NA and SC 2009-2013.
So both the early XF with the "Duratec" 3.0 V6 (NA only) aka the AJ30 and the later (2012 onwards) AJ126 (SC only), but supposedly prior to the 2012 "facelift" let alone the 2015 X260.
I dunno for sure but I doubt that the OEM exhaust systems for the AJ30 and AJ126 are identical so my WAG is that some modification/fabrication may be needed to fit this system to either or both of the AJ30 and AJ126.
Old Dec 29, 2024 | 06:47 PM
stan879's Avatar
Hi Jssaab.
Did you end up installing it. I have the kit, its been sitting around for a 6 weeks haven't even opened it yet. been working my way through a 100k miles service using Dennis Easy 300.000 plus miles and Bens muthalode task guide.
Beginner
E type ( XK-E )
Jan 26, 2022 10:43 AM
Tcasmarcus
Jul 22, 2018 06:17 AM
johnhdz21
Sep 30, 2012 08:20 AM
swampy
Oct 29, 2010 09:49 AM
