20" volan wheels tyre and spacer info. required
Old Dec 14, 2011 | 10:25 AM
MXF's Avatar
MXF
Default 20" volan wheels tyre and spacer info. required
I have just purchased these wheels and I have 2 questions.
1. Do i need to fit spacers?
2. What is the correct tyre fitment for front & rear?
Any help appreciated.
Mark
Old Dec 14, 2011 | 11:13 PM
duke_dallas's Avatar
Mark
1. What car are you putting them on?
2. Stock sizes are 255/35, 285/30
Old Dec 15, 2011 | 01:49 AM
MXF's Avatar
MXF
Hi duke
I am putting them on an XF, thanks for the tyre info.
Old Dec 15, 2011 | 09:44 AM
Hi duke
What year and model of XF? The only vehicle I'm aware that the Volans came stock on was the '09 XF Supercharged. The offset on the rear Volans are higher (but they are also wider) than other wheels available that year. So, spacer? Maybe, if you have a non-supercharged variant.
Old Dec 15, 2011 | 11:08 AM
MXF's Avatar
MXF
Hi again duke!
My car is a 2009 XF 2.7 V6 diesel, they are to replace the stock 18" wheels that came with the car.
Old Dec 16, 2011 | 10:01 AM
There should be no need for a spacer up front. In the rear, I'd mount without and see how it looks/drives. I doubt you'll need one in the rear either but if they appear to sit a little too far inboard, you might try a small spacer.
Old Dec 16, 2011 | 10:55 AM
MXF's Avatar
MXF
Thanks duke, I will follow your advice.
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
Matei Dima
Oct 8, 2015 11:45 AM
metalmarty
Sep 11, 2015 07:05 AM
fingers
Sep 8, 2015 03:54 PM
