2009 xf issues ?? New member ..
Old Oct 2, 2015 | 10:29 PM
Timothy Luke's Avatar
Default 2009 xf issues ?? New member ..
Hello all ... I'm new to the forum. Didn't see an introductory post so Im just gonna go ahead and get into it I purchased my 09 xf premium luxury in January and haven't had any problems till now. I had a code for the secondary air pump after looking under the hood I noticed my hose was brittle and broken in half I replaced the hose bought it from Jaguar for $75. Seemed like it fixed the issue except now there is a hissing sound coming from part of the engine I've uploaded a pic and circled the part I took it off made sure there were no cracks or leaks put it back together and when I turn the car off it sounds like the last bit of air is being squeezed out like when you shut off an air compressor. Any help? Suggestions? I'm figuring out I probably should be a jag owner. Thanks in advance.
Old Oct 3, 2015 | 12:24 PM
DPK's Avatar
DPK
Compliments on a nice clean engine...The 4.2L I'm not familiar with..I'm sure help will be on the way soon.
Old Oct 4, 2015 | 02:18 PM
calviroman's Avatar
"hissing when the engine is running" or ONLY for a second during shutdown? If #1, you have a vacuum leak, if #2, you likely have no issue at all.
Old Oct 5, 2015 | 10:21 AM
tbird6's Avatar
If no codes you are OK. Even hearing a hissing does not mean it's a vacuum leak.
Have you checked for codes?
Bcrary3
Sep 12, 2015 08:43 AM
rudelover2
Sep 11, 2015 08:53 PM
xj3502005
Sep 1, 2015 04:03 PM
bluerdg
Sep 1, 2015 08:07 AM
zecretw
Aug 31, 2015 04:02 PM
