2009 XF Premium strangeness
Hi folks
I have a couple of weird things going on with my 09 XF.
First - Rear view camera works fine when the car is first started, but ends up green if it's warm outside or I've been driving it a bit.
Second - Nav screen is totally black.
Third - the first two only started happening after I replaced the battery.
SO - the questions are:
First - Can I try to reset everything now that I'm post-battery replacement?
Second - I did have issues with the trunk latch that was fixed with a quick solder job. Should I replace the harness from the body to the trunk? and if so, what's the part number?
Third - For the Nav - do you think popping the DVDs (from 2008) and putting them back in would help? Or just cough up for the latest (2015) version?
Thanks in advance.
Z
Thanks in advance.
Z
Quite possible.
I'd love to just replace that connector between the body and trunk, but I'm out in the boonies and need to order it on-line as the nearest JLR dealership is at least 8 hours away.
Thanks for the reply!
Z
Z
Yes. Once one wire breaks it's only a matter of time before others do. They have a redesigned replacement harness. Easy fit. Part number C2Z19874 I think. You can order and have it mailed. I replaced on my 2010 years ago. Was under $150 for the part I think.
dorothysplayhouse
Sep 26, 2017 10:36 PM
