2010 Jaguar XF 4.2L throwing code p0184
Old Oct 6, 2021 | 02:53 PM
Kafj's Avatar
Default 2010 Jaguar XF 4.2L throwing code p0183
Hi guys I’m new here” my name is Kerry..
hopefully someone can help me. Recently my check engine light came on. For code p0183 fuel pressure sensor. My question is should I just replace the sensor? Car still runs flawlessly. Only problem is, car is burning gas faster than usual
Old Oct 7, 2021 | 01:48 AM
JagV8's Avatar
Could be wiring or sensor - check which & fix as needed.
Old Oct 7, 2021 | 07:27 AM
Kafj's Avatar
Default Fuel temp sensor trouble
Good morning guys I really need ya’ll help 🙏🏾 😩
my 2010 Jaguar XF 4.2L v8 runs beautifully. but recently check engine light came on for code p0183
fue temp sensor.
I need to know if this part is under the the hood or in the fuel tank?
car still runs good, but sucking up gas very fast!
please help
Old Oct 7, 2021 | 09:40 AM
Kafj's Avatar
Default Code p0183
Gm
Could someone please help me locate fuel temp sensor on 2010 Jaguar XF 4.2L v8
Old Oct 8, 2021 | 01:09 AM
litteredwithfaults's Avatar
You need the workshop manual. If you google a bit it can be found free like this one
https://www.dropbox.com/s/itzjq6rti2...anual.pdf?dl=0
Search that and
Fuel Pressure Regulator on page 1516
Fuel Temperature Sensor on page 1974
Old Oct 8, 2021 | 02:25 AM
I've merged your THREE separate threads on this same question here and deleted a FOURTH from the US Lower Atlantic Region forum. Do NOT multiple post the same question.
I replied to your Intro advising this code can indicate either a faulty sensor or a harness fault. JagV8 has given you the same advice in post #2 and litteredwithfaults has given you a link to download the Workshop Manual in post #5.
The Workshop Manual gives detailed information on the Fuel Temperature Sensor (item 5):
CSmith22
XF (X260)
Sep 28, 2020 08:01 AM
Andrew Dodds
Nov 5, 2018 01:22 PM
wesleysteven
Apr 8, 2018 10:55 AM
darrellleece
Aug 25, 2017 10:56 PM
mick99
Feb 1, 2016 10:51 AM
