2010 Jaguar XF Center Dash Will Not Power On
Old Nov 18, 2016 | 03:16 PM
tgordo's Avatar
Default 2010 Jaguar XF Center Dash Will Not Power On
Everyone, my Jaguar's center information center will not power on to include my climate controls. I purchased this salvage car with these problems, where I removed the wet carpet in the vehicle and saw that the three modules under the driver's seat were removed and the single module under the passenger's seat. I reinserted the modules and checked the fuses and relays, which appeared functional. I need help troubleshooting this car to get the information center along with the climate control operational. Thanks Jag Owners!
Old Nov 18, 2016 | 03:53 PM
stmcknig's Avatar
Water damage salvage ? Mistake #1.
Old Nov 18, 2016 | 05:02 PM
BritCars's Avatar
Did you buy new modules or put back in the old ones? Which modules are you referring to - there are a lot
If you don't have the full service manual or a topix subscription I think you're going to need one...
Old Nov 18, 2016 | 05:38 PM
tgordo's Avatar
Everyone, thanks for your quick replies. Below are the modules I had initially referred to:
Driver's side:
C241471, Satellite Receiver Module--ordered a new one and installed it
C2Z11365, Telephone Bluetooth, ordered, should arrive next week
C2P19340, Stereo Audio Radio Module, ordered, should arrive next week
Passenger's Side:
C2P25960, Tire Pressure Module (ECU), ordered, should arrive next week.
In the meantime, I reinstalled the original modules (3) except the Satellite Receiver Module as stated above. I did purchase a repair manual for the car. I am hoping that replacing all of the modules under the driver's seat, which are for the audio/infotainment system, the display will come on. The module under the passenger's seat is for the tire pressure monitoring as you know.
BTW, when I removed fuse #26 in the RJB and reinserted it, the infotainment system came on displaying the Jaguar logo (I assume it rebooted the system) and then went off! My objective is to get the center console (infotainment system) to come on so I can operate the climate controls, radio, etc.. I have a repair shop wanting to run a pin test to evaluate the network, power, grounds. I am trying to avoid being charged a ton of bucks to do work that I can do. I hope this forum can help me with this repair. With thanks.
Old Nov 18, 2016 | 05:56 PM
tgordo's Avatar
Everyone, I am sharing my manuals.
https://1drv.ms/f/s!AklJDVffq6lewEcdY_NKW5SPJKVu
Old Nov 19, 2016 | 12:49 PM
timfountain's Avatar
I wouldn't be at all surprised if most or all of those modules need marrying to the car.... I doub't you can just plug them in an hope for the best.
OP - What why was the car written off, i.e. what exactly is supposed to have happened to it? It is possible you are barking up the wrong tree WRT to this issue.
Old Nov 19, 2016 | 04:10 PM
tgordo's Avatar
Thanks for your reply. The car had an accident, hence the write-off. All of the modules arrived today, had my fingers crossed, but no cigar. Back to square one.
Old Nov 21, 2016 | 10:54 AM
Injekter's Avatar
make sure your battery is good as well
