2010 supercharged white smoke
Old Jan 4, 2016 | 09:10 AM
Badcatt's Avatar
Default 2010 supercharged white smoke
(Xf) Any help is appreciated- was driving got the restricted performance message pulled over then whitesmoke started coming from the rightside exhaust went to a nearby partstore had them run a scan got coil codes and a multiple misfire code its also gas burning raw has a horrible smell tank was full to limp bk home which was under 10miles smoke was blowing and gas went to 88miles off of 224
Old Jan 4, 2016 | 10:42 AM
tbird6's Avatar
Yes. Post the codes.
Is the oil level OK?
Is the coolant level OK?
Old Jan 4, 2016 | 10:55 AM
n8ertot's Avatar
Also, what did it smell like? Sweet? Nothing?
Old Jan 5, 2016 | 02:03 PM
Badcatt's Avatar
@tbird 6 I misplaced the paper but it was all 4 coils on the right side of the engine and also a code for multiple misfire
Old Jan 5, 2016 | 02:08 PM
Badcatt's Avatar
n8ertot it wasn't that sweet antifreeze smell its more of a raw gas blowing out It went from a full tank to empty almost cranked again this a.m gas was on about 80 let it ran for about 5-10 min it dropped down to about 60 to empty just touched 70,000 sat
Old Jan 5, 2016 | 02:09 PM
Badcatt's Avatar
Also Oil and coolant are fine
Old Jan 5, 2016 | 04:14 PM
tbird6's Avatar
If you have a code for coils I would inspect them on that side and report back. Sounds almost like an electrical problem on one side of the engine because 4 coils don't go out all at once.
If you don't find anything I would swap the coils from side to side and see what happens.
Are you able to DIY at all? It will be MUCH cheaper!
Old Jan 5, 2016 | 04:54 PM
Badcatt's Avatar
Tbird6 I wish I could hadn't had a chance get it the dealership because the nearest is 91miles away and the booked til next Tuesday I've talked with the tech there saying possible injector is stuck open
Old Jan 5, 2016 | 06:48 PM
DPK's Avatar
DPK
Don't keep running it much until you find the problem why one side of the engine isn't firing..I understand raw gas can damage the Cats.
Old Jan 6, 2016 | 06:51 AM
sparkenzap's Avatar
Not only that, but you can wash the bores and cause mechanical damage to the engine.
It is probably not an injector since you have 4 cylinders misfiring. The diagrams show all four coils are fed from a common supply, so it is not a fuse. That leaves a ground or something in the ECU or wiring, or a sensor lousing up the engine management.
Old Jan 8, 2016 | 11:16 AM
Kaeghl's Avatar
so there is no coolant smell from the engine bay or anywhere else? Does the coolant overflow tank have a lot of pressure in it when you remove it?
let me guess, 20 10 xf supercharged about 50-60k miles on it?
Lets hope it is "just" and injector but it sounds like a head gasket.
The heads were produced poorly from the factory, they used the gasket to take up the slack but they don't last and you get a failure which can ruin an injector and make it stay open. See if there is a lot of pressure in the coolant overflow or if you are losing coolant. Do you have to top up the coolant frequently? If not then it may just be a stuck injector. They can be gotten to fro the top of the engine so the damage shouldnt be too bad if you take it to a respectable shop, the dealership will charge you insane prices.
Old Jan 9, 2016 | 02:42 PM
Badcatt's Avatar
Thanks for the help guys I got it to the shop they've came up with three possibility ECU,Cats or Injectors They told me Monday they'd know for sure I will post back when they actually let me know
Old Jan 9, 2016 | 02:46 PM
Badcatt's Avatar
Kaeghi want the supercharger have to be removed if that's the problem cause the where I'm assuming it needed to be where it is I had diff people tell me the injector but was like they didn't want bother with that supercharger if it was the case
Old Jan 9, 2016 | 06:06 PM
DPK's Avatar
DPK
Please tell me you were texting this while driving, otherwise, how many drinks did you have before typing this or what were you smoking??..
Old Jan 12, 2016 | 01:48 PM
Rdyoung's Avatar
I had the same thing happen and it was one of the fuel injectors. The Jag dealer replaced it and it has run fine ever since.
Old Jan 12, 2016 | 02:40 PM
Gpalace's Avatar
Badcatt.....any status? hope not too pricey.
Old Jan 12, 2016 | 02:44 PM
Kaeghl's Avatar
My guys got to the injectors without pulling the blower or the engine. The spark plugs and injectors are not in the valley, they are on the outside by the headers.
Check ebay for the injectors, you need them new in package. You will also need a few weird tools and the teflon sleeve to compress the injector gaskets (they are a dry style).
Old Jan 12, 2016 | 09:22 PM
sparkenzap's Avatar
Again, not buying the analysis of an injector, assuming the 4 cylinders are all misfiring as reported.
Old Jan 13, 2016 | 07:50 AM
DPK's Avatar
DPK
As Zap said...All four would happen at once..Still believe it is and electrical ignition or ECM issue.
Old Jan 13, 2016 | 10:06 AM
Kaeghl's Avatar
One injector being stuck open can "flood" the other cylinders.
This is a very inaccurate description of what is going on but one injector can show misfires on multiple cylinders.
