2010 XF Battery Warning
Old Feb 3, 2021 | 03:39 PM
fredpribyl's Avatar
Default 2010 XF Battery Warning
I installed a new battery and the little wire I think sensor was broke so I fixed it but now with the new battery the Warning Red comes on i can't clear it.
Old Feb 3, 2021 | 03:43 PM
John Williams's Avatar
That wire (red/blue) has a lead section at the end which is a fuse, if that has broken/blown then the light will show! It's called a "fuselink"
Old Feb 4, 2021 | 04:46 AM
fivel's Avatar
I've got exactly the same thing. I had the battery out because I was working on the car (charged it whilst it was out), reconnected it and now have the red battery light. Charging circuit is runs at 13.8V when it kicks in so that seems ok. It has a B11DB87 DTC logged, which the manual says:
I happened to have another BMS so swapped them over but that made no difference, and I haven't looked into it any further because its too cold and wet to be outside fiddling with it.
You think that this is the same fused link lead that's failed in this case too (and part C2Z12463)?
I suppose I can test the resistance on the lead from the battery connected end to the BMS to see if its blown.
Old Feb 4, 2021 | 07:45 AM
Give the cable a tug, as the link is held inside some heat shrink, so could be fractured internally.
fredpribyl
XF (X260)
Jan 23, 2021 03:40 PM
fredpribyl
Nov 13, 2020 01:04 AM
Marthamtz
XF (X260)
May 19, 2020 01:51 AM
Andy Brown
Jan 24, 2019 09:01 PM
carzaddict
Jan 31, 2017 03:19 PM
