2010 XF not starting. Battery issue?
Old May 13, 2013 | 02:49 PM
  #41
finalfan7asy's Avatar
Originally Posted by jaglover922
I Know what your problem is but I'm not going to tell you. Techs within the Jag community keep info to themselves, so unless your battery is bad, then there is a drain. But chances are your battery is straight up bad. Jaguar doesn't make their own batteries. There is really only a few battery manufactures in the world. They just slap different stickers on the batteries. How often do you drive the car anyway? Does it sit? Was it sitting for more then a few days before you started it?
It's driven every other day if not more and the battery was recently replaced.
Old May 13, 2013 | 07:09 PM
  #42
hlgeorge's Avatar
I also don't want to reveal info so that you would not have to take your car into the dealer or Jaguar Specialty shop for work.
But isn't that what we are all about? Helping each other have the best experience with this wonderful car. I would share any information that would help a fellow Jaguar owner have the best information he/she can have to make life with this car the best experience the they can have.
Old Mar 1, 2014 | 06:31 AM
  #43
MCW's Avatar
MCW
And the final solution was?
Old Dec 29, 2019 | 08:14 AM
  #44
Phavas's Avatar
Angry
Originally Posted by jagular
The state of the original battery is not affected by jumping. Any jumper cables are connected in parallel to the car battery and no current passes through the dead battery. Any charging happening would feed both the dead battery and the jumper battery simultaneously. The jumper battery cannot charge the car battery.
If the engine won't turn over with a jump from a known good battery then your problem is with the starter or its wiring. The alternator is never relevant to a fail to start except if it is the cause of the dead battery. A failed alternator will not prevent the engine from starting and running.
This statement is just wrong. A dead battery, one with an internal short, a shorted alternator, all will prevent the car from starting. The power source first goes to the drain, if it’s in the battery it will go there first, in the alternator straight to ground. A good battery will definitely charge a low one if its not shorted.
Old Jan 8, 2020 | 01:35 PM
  #45
dotcom's Avatar
Default Bluetooth battery monitor app
I’ll share what I’ve done with the hope it helps somebody.
BUNKER INDUST Battery Monitor BM2...
Amazon Amazon
Forcedair1
Sep 8, 2025 01:57 PM
JarodL
Mar 7, 2024 01:39 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
obwoodie
Sep 3, 2015 07:45 PM
OkieTim
Sep 2, 2015 12:48 PM
