2010 XF Supercharged tuning
Old Jun 9, 2018 | 11:36 AM
Supercharged81's Avatar
Default 2010 XF Supercharged tuning
I have been convinced from the forum members here and local mechanics to soon opt for an ECU tune. 2010 XF Supercharged. Has anyone here tuned their XF Supercharged? I want to know if just the ECU tune will get me to into the 500hp range. The tuning companies claim it will. Thank you forum members.
Old Jun 9, 2018 | 12:52 PM
Bigg Will's Avatar
Yes it will, the only MAJOR difference in all the Jag AJ133SC versions is the state of tune.
Old Jun 9, 2018 | 02:51 PM
Default Thanks.
Thanks again. I will definitely be getting a ECU tune.
Old Jun 9, 2018 | 07:15 PM
OzXFR's Avatar
Many reports from Cambo that the 495 hp Supercharged motor very likely really has the same 503 hp as the XFR motor, and Jag simply under-quoted it so as not to take away from the XFR.
A simple tune such as one from Velocity AP will take it to around 550 hp (same as the XFR-S and F-Type R), and if you go with a pulley swap (either smaller upper pulley or larger lower/crank pulley although the lower pulley is preferred) you can take it to 600 hp+.
You would be looking at around $1,000 for just the tune and around $2,000 for pulley + tune.
sales@ECU Tuning Group
May 27, 2020 10:50 AM
May 6, 2020 11:26 AM
Supercharged81
Jun 6, 2018 06:20 PM
Erik@RSC
Feb 15, 2015 04:28 PM
09sleeper
Jul 6, 2014 10:20 PM
