2010 XK 5.0L P0500 code; Vehicle Speed Sensor "A"
Old Today | 07:45 PM
mturner7's Avatar
Default 2010 XK 5.0L P0500 code; Vehicle Speed Sensor "A"
2010 Jaguar XK 5.0L has four speed sensors—one for each wheel. I'm getting a P0500. It happened just after replacing the Battery.
Duralast Platinum H8-AGM; Group Size 49
Deep Cycle Capability:
Cold Cranking Amps (CCA): 900 A
Reserve Capacity (RC): 160 minutes
Amp Hour (Ah): 92 Ah - 95 Ah
Voltage: 12 V
Dimensions: 13.94" L x 6.94" W x 7.50" H
Weight: 58.2 lbs
Warranty: 4-Year Free Replacement
NO engine Light, no other codes; I had an "Oxygen Sensor INC, up uintil two days ago and it finially went RDY.
Does anyone know which speed sensor is "A"? Someone said it's the right rear?
I tried to Monitor the live wheel speeds while driving to isolate which sensor is dropping out or reading erratically, but my $350 scanner does not have that option. So, I ordered all 4 sensors and going to replace all of them. Does anyone know if the code will just clear after I replace the bad one? It's listed as "Permanent" and can't be cleared with the scan tool. The car also failed California Smog yesterday because of this!
Anyone???
Tracee
May 27, 2025 02:05 PM
Patrick 1989 XJS
Feb 1, 2025 07:17 PM
ZenFly
Jan 15, 2021 05:09 PM
1951sms
Aug 11, 2019 12:03 PM
butch h
Oct 29, 2016 05:38 AM
Currently Active Users Viewing This Thread: 22 (0 members and 22 guests)
