2010 XK 5.0L P0500 code; Vehicle Speed Sensor "A"
2010 Jaguar XK 5.0L has four speed sensors—one for each wheel. I'm getting a P0500. It happened just after replacing the Battery.
Duralast Platinum H8-AGM; Group Size 49
Deep Cycle Capability:
Cold Cranking Amps (CCA): 900 A
Reserve Capacity (RC): 160 minutes
Amp Hour (Ah): 92 Ah - 95 Ah
Voltage: 12 V
Dimensions: 13.94" L x 6.94" W x 7.50" H
Weight: 58.2 lbs
Warranty: 4-Year Free Replacement
NO engine Light, no other codes; I had an "Oxygen Sensor INC, up uintil two days ago and it finially went RDY.
Does anyone know which speed sensor is "A"? Someone said it's the right rear?
I tried to Monitor the live wheel speeds while driving to isolate which sensor is dropping out or reading erratically, but my $350 scanner does not have that option. So, I ordered all 4 sensors and going to replace all of them. Does anyone know if the code will just clear after I replace the bad one? It's listed as "Permanent" and can't be cleared with the scan tool. The car also failed California Smog yesterday because of this!
Anyone???
Voltage: 12 V
Weight: 58.2 lbs
Anyone???
ZenFly
Jan 15, 2021 05:09 PM
