2012 Jag Portfolio
Old Dec 11, 2018 | 07:07 PM
So Charlie's Avatar
Default 2012 Jag Portfolio Alternator Change
Just pulled the alternator out. Thirty minutes or less.
1.Jack up passenger side of the car for access.
2. Unhook battery, leave trunk open.
3.Undo radiator top hose.
4.Remove serpentine belt
5.Remove small pulley right above alternator.
6.Remove top alternator bolt.
7.Acess and remove two remaining bolts from bottom of alternator.
8.Alternator should be loose, turn and disconnect back plug.
9.Disconnect B terminal.
10.Alternator should slide right out the bottom with a little wiggling.
Hope this helps for
Jesse James
Feb 21, 2019 04:45 PM
croco
May 24, 2018 12:11 PM
Mtnr91
Oct 23, 2011 03:12 AM
Bruce H.
Oct 10, 2011 01:45 AM
Frogdogfan
Aug 23, 2011 03:06 AM
