2012 Jaguar XF
Old May 5, 2016 | 02:45 PM
Tbclarke's Avatar
Default 2012 Jaguar XF
My 2012 Jaguar XF with 28,000 miles, the engine died at stop light and the would not start. The a/c vents flip, screen turns on. The engine trys to turn over and once did start but dies when take foot off brake. Thoughts?
Old May 5, 2016 | 03:00 PM
NBCat's Avatar
Is the MIL on and if so, what DTCs are stored in the system?
Does the vehicle have fuel pressure?
Has any work recently been done to the engine, ignition or fuel systems?
Did the vehicle run hot, or did you hear any abnormal noise(s) prior to it not starting?
What road and weather conditions were present and what type of driving?
Old May 5, 2016 | 03:12 PM
Tbclarke's Avatar
- nothing showed on dash -- code etc. just read exclamation mark.
- Not sure. I just purchased 2 weeks ago.
- Not that I am aware. Just purchased.
- Did not run hot and heard no noises. However, 2 days ago the Check Tire Pressure came on then went off. Did this 3x and each time was a different tire. Not sure if related.
- I was in the city on a city road and sunny and 84 degrees.
Old May 5, 2016 | 03:51 PM
Injekter's Avatar
Old May 5, 2016 | 03:57 PM
NBCat's Avatar
'- nothing showed on dash -- code etc. just read exclamation mark.'
I assume you mean red exclamation mark?
What is the voltage at the battery terminals?
Old May 5, 2016 | 10:25 PM
BritCars's Avatar
Does it have fuel??
Old May 6, 2016 | 07:02 AM
DPK's Avatar
DPK
I bet it's the battery crapping out..
That does it...I'm getting mine changed this month..whether it needs it or not...while it's still under warranty.
Old May 13, 2016 | 05:02 AM
Bigg Will's Avatar
Getting warmer and weak batteries are starting to GO....LOL Start there.
richard1159
Apr 16, 2016 07:54 AM
thedugger1
Apr 14, 2016 12:10 AM
Miami XKR
Apr 8, 2016 09:56 AM
Jaguar Forums Editor
Jaguar Press release
Apr 7, 2016 08:58 AM
silversurfer1221
Apr 6, 2016 05:26 PM
