2012 XF dashboard
Old Dec 5, 2022 | 06:05 AM
Jeff001's Avatar
Default 2012 XF dashboard
Hi all,
new to the forums but wanted to touch base with other XF owners and techs.
so I have a 2012 XF portfolio which means my dash is garbage.
I removed the dash so I could either get it fixed or replaced.
when I removed the dash I found there is a foam pad that the dash sits on at the base of the windshield
when I checked the padding it was very wet.
I’ve noticed in the past when I first start the car and turn on the windshield vents I get condensation on the inside of windshield for a moment.
now I know why.
question is does anyone know why this padding gets wet or how to fix it?
Tks in advance.
Old Dec 5, 2022 | 12:50 PM
Welcome to the forums Jeff001,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to X250 forum. Members here with the same model will be able to help.
Enjoy the forums.
Old Dec 5, 2022 | 04:44 PM
karamayoko's Avatar
man aint I glad to live in the Sonoran desert region now lol as the sun here would literally dry that up in a couple of hours. I've never read such things happening before, very unfortunate position to be in sorry too hear about this. hopefully someone can come and InSite some true help.
Old Dec 14, 2022 | 12:42 PM
Richard Zuniga's Avatar
Default dash 2012 xf
yea the same problem(not the wet dash tho)
the wrinkled and detached dash as well as the broken center speaker grill
what a buncha junky crap for an expensive luxury car
I wish there was a shop in the San Antonio TX area to do this kind of repair because the dealership wanted like 5K+ to fix it ...
Old Dec 18, 2022 | 09:29 AM
Jssaab's Avatar
ANohter thing to check is the sunroof... look to see if the wet seems to be startgin around the base of the a pillars. If so the sunroof nuts may need to be tightened (common problem) You can get to it with out removing the headliner, jsut pulling it down around the frame
Old Dec 19, 2022 | 05:42 PM
sov211's Avatar
Another possibility for the moisture and the damage to the dash cover? has the windshield been replaced at some point? If so, there is your likely suspect - an improperly seal windshield.
Fredclum
Jul 16, 2018 05:17 AM
Jazzzz
Dec 15, 2015 07:01 PM
ADJag
Oct 21, 2012 07:42 PM
