2013 XF Radio, Backup Camera, Locks not working
Subscribe
Dec 14, 2020 | 09:23 PM
Hi all, A few weeks ago, I left the drivers window down and we had a rain storm overnight. Now, my radio is not working nor is my backup camera and door locks. I pulled the seat out and find that the Sirius module looks fairly corroded. Would that unit also be responsible for my door locks and backup camera not working? Please let me know your thoughts and what other modules, etc. I will need to check.
Thank you, Chris
P.S. Apologies for having mistakenly posted this into the Current (2015 +) model thread earlier.
Reply 0
Dec 15, 2020 | 04:17 AM
You've obviously got an electrical fault. This module has nothing to do with the door locks itself.
I'd disconnect the battery, dry the car out fully, check all the fuses, charge the battery and connect it back up and run a diag and see if any modules are reporting errors or not found at all.
There's not a lot of info to go on so at a total guess I would start with leaving the Sirius module out to see if its shorting something and check the door module and its wiring, look for corroded connections etc. Then work around all the electrical things that might have gotten wet or shorted by something else getting wet and check they are all working properly.
Reply 0
Dec 15, 2020 | 07:33 AM
Check the door switches for water. Remove the seat and check under the carpet for water. Canbus issues.
Reply 0
Dec 15, 2020 | 09:34 AM
Thanks guys. Yes, I've pulled the driver seat and carpeting - was soaked. I ordered a replacement sirius module and will install. I'm thinking there may be damage to the door switches which is causing the locks not to function. I'll clean up all contacts and try resetting. Will keep you posted...
Reply 0
Subscribe
Currently Active Users (1)
