2018 Sportbrake humming noise
Old Apr 8, 2023 | 04:01 PM
2JagSyndrome's Avatar
Question 2018 Sportbrake humming noise
I recently purchased a 2018 XF Sportbrake. I am not new to late(r) model Jaguars, but this is my first XF. I am not sure what are "normal quirks" and what may require attention, coming to the forum for some help. When I unlock the car there is a humming noise which begins emanating from under the hood. As best I can tell it is the right-front of the car. (passenger front, LHD). After the car has been driven and parked, when I exit the vehicle I can hear the noise again. The car will continue to make this noise indefinitely, although I imagine eventually it must time out. If I lock the car, it will silence the noise, but it is not instantaneous. Just curious what this noise could be, and if its normal for the XF, or it is indicative of a pending failure/problem. Many thanks.
Old Aug 10, 2024 | 08:18 AM
ats007's Avatar
I hear the same noise. Did you ever find out what the cause was?
Old Aug 10, 2024 | 11:02 AM
clubairth1's Avatar
Community Influencer
One possible source is the LED headlights as they have a built in cooling fans since they run so darn hot. This fan can and does run after the car is shut off too.
But this is just a guess.
Jagxjl50
Jul 20, 2022 07:34 AM
pmckool
Dec 13, 2019 03:23 PM
Elizabeth Blake
Sep 17, 2019 08:12 PM
Geoffc2411
May 24, 2018 09:01 AM
