305/30/20 tires, do they fit?
Old Mar 2, 2015 | 12:48 AM
blown Jag's Avatar
Default 305/30/20 tires, do they fit?
I am looking into buying a XFR and would like to know if 305/30/20 size tires are going to fit well. I am planning to put these tires on a 20" by 10" wide mags.
Thanks,
Marco
Old Mar 2, 2015 | 01:28 AM
OzXFR's Avatar
Should fit OK on the rear, could be problems on the front. But I guess you are talking about the rear only.
Assuming you already have 285/30/20 rear tyres, and assuming the new rims are the same offset as what you already have, then the new tires will stick out an extra 10 mm in each direction and fill out the wheel well by an extra 6 mm.
I use this calculator: Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Old Mar 2, 2015 | 03:15 AM
Mr Sharky's Avatar
My tires rubbed when the car was fully loaded and cornered hard. I only had that size in the rear though. I would think that they might rub quite a bit in the front.
slojotaa
Oct 16, 2019 10:22 AM
MrWest
Dec 1, 2015 09:18 PM
smith356
Oct 7, 2015 06:41 PM
johndahlheimer
Sep 16, 2015 05:44 PM
KarimPA
Sep 12, 2015 08:15 AM
