! 59 Plate XF 3L V6 - Electric Issues HELP !
Old Apr 23, 2021 | 04:25 PM
XF-MICHAEL's Avatar
Lightbulb ! 59 Plate XF 3L V6 - Electric Issues HELP !
Hi All,
New to the forum and looking forward to chatting with you all.
I sold my XF and missed it so bought it back.
Since getting it back I have a few issues I hope you may be able to help with?
Firstly the steering column adjustment doesn't work?
Secondly the passenger front and rear electric window have both stopped working?
And Finally when I unlock the car with the key only the drivers side will unlock?
I would appreciate your help if possible.
Michael
Old Apr 24, 2021 | 04:35 AM
fivel's Avatar
The first thing you can do is scan for DTC's to see if the car is trying to tell you what's happening before trying to work your way through all the electrical and modules issues it might be having. The door unlocking is probably just be because its set to single point entry:
"Your vehicle can be unlocked using either Single or Multi-point entry. Single-point entry is a security feature that only unlocks the driver's door when the unlock button is pressed.
To change from Single to Multi-point entry (or vice versa), press both the lock and unlock buttons simultaneously for three seconds. The hazard warning lamps will flash twice to confirm the change."
Johnny Mayday
Jun 18, 2017 09:08 PM
tberry6686
May 12, 2017 02:28 PM
Cherry_560sel
Nov 26, 2016 01:15 AM
mranraj
Sep 5, 2016 03:45 AM
Maz
Apr 4, 2014 03:15 AM
