AC anomalie
Old Apr 25, 2022 | 01:57 PM
John8's Avatar
Default AC anomalie
Hi guys,
I have an XF 2013 3.0d.
My AC seemed to be working fine a couple of months ago but when I went to use it today, there is no coldness at all.
I put the temperature on 17 and pressed auto. I could see the AC was on on the screen but just not cold whatsoever.
Apart from maybe a re-gas, could something else affect this, electrical etc... It just doesn't seem right that the gas is suddenly gone.
Any help would be appreciated.
Old Apr 25, 2022 | 03:49 PM
John Williams's Avatar
Might help....
Old May 16, 2022 | 12:30 PM
John8's Avatar
Thanks for the reply John but I think this is a little advanced for me.
I would need to know that this is definitely the problem.
Old May 16, 2022 | 12:35 PM
John8's Avatar
An update on the symptoms...
It seems to be blowing cold air on the passenger side only.
When I sync both sides, it is still just blowing cold on passenger side.
When I control both sides independently, and turn drivers side to lowest setting, it is still only cold in passenger side.
This only tells me that it doesn't need re-gassing.
Any thoughts?
Old May 17, 2022 | 03:12 AM
POD XF's Avatar
Probably one of the stepper motors that control the various flaps of the climate control unit has died. Not sure which though.
If I were troubleshooting this, I think I'd manipulate all the climate control settings whilst observing the stepper motors and see if there is one that does not move no matter what settings you change. Then remove that stepper motor and move the lever manually, see if you then have cold air. If my recollection is correct, there are 4 stepper motors on the climate control unit, a couple of them are fairly easily accessible and a couple are...not....
Old May 19, 2022 | 01:27 PM
John8's Avatar
Thanks for the reply.
Where are the stepper motors located, are they easy to get to?
chillyp
Sep 9, 2021 06:52 AM
DuhCar
Jun 30, 2021 10:44 AM
tford
US Northeast
May 31, 2011 11:03 AM
