ACC and Front License Plate
So I just got around to putting away my front license plate mount as here in Indiana we only use rear plates. I noticed that there is writing on the plate mount that says “Do not use with ACC”. What does the front plate mount look like if you have Adaptive Cruise Control? Is it on the side or something? Just curious.
Attached is a little something to explain the placement of the front plate plinth on both ACC and Non-ACC equipped cars. Placing a metal license plate in front of the ACC radar unit does cause issues. Once you have a few more posts up you will be able to access the document.
Cheers,
