Accelerator pedal
Old Feb 19, 2016 | 08:26 PM
boiler's Avatar
Default Accelerator pedal
Anyone know what that white thingy does at the base of the pedal? I noticed recently when I pressed hard the pedal felt notchy so I took it off and found that white thing. When pressed hard it pushes the white piece into the black plastic and gives the pedal about another 1/8" of travel.
Old Feb 19, 2016 | 08:43 PM
boiler's Avatar
So I took my obd reader and looked at the throttle position. When pressed to the white "button thingy" the throttle percentage is 80% when the button thingy is pushed in throttle position increases to 90%. Not sure how to get to 100%
Old Feb 19, 2016 | 08:49 PM
Humphrey's Avatar
Kickdown trigger? But I don't understand why it would be only 90% throttle at full gas.
Old Feb 20, 2016 | 03:20 AM
JagV8's Avatar
It's probably a dummy (electrically) to give the right mechanical feel.
The PCM calibrates the accel pedal so the percentages don't much matter as it figures them out. You won't see 0% for no pedal, either.
Many cars have done this for a couple of decades and it just works.
Old Feb 20, 2016 | 02:03 PM
boiler's Avatar
You are correct, after some scientific testing on the highway if you floor it in 6th gear it will not downshift and the throttle only reads 80% if you activate the kickdown trigger it drops a few gears and the throttle position reads 90%.
Old Feb 22, 2016 | 05:38 PM
Tuning@VelocityAP's Avatar
Yep it's a kickdown switch. Also the pid your looking at is a absolute throttle pid of the exact location. The manufacturer doesn't make this 100% accessible, unless its the calculated position. They will use anything above X% and any thing below Y% to trigger a fault with the throttle pedal range.. Regardless anything above 80% whether it be absolute/relative/calculated is going to be full throttle
__________________
________________
Christopher Edgett
Technical Director
Velocity Automotive Performance Limited
214 Maple Ave.
Oliver, BC
Canada V0H 1T9
Office Tel: (250) 485-5126
www.VelocityAP.com
Tuning@VelocityAP.com
Davfrankl
Feb 17, 2016 10:46 AM
Miami XKR
Feb 12, 2016 06:04 AM
superA
Feb 5, 2016 08:21 PM
VinnyT
Feb 5, 2016 11:22 AM
AtomSmasher
Feb 4, 2016 10:07 PM
