Adaptive dynamics fault replaced front struts
Old Jun 10, 2024 | 02:42 PM
gretle_2.0's Avatar
Default Adaptive dynamics fault replaced front struts
Hey all, I recently replaced my front struts on my 2010 XF supercharged with used oem active dynamic shocks. Now it worked completely fine for a few days and I noticed clunking in the front, ended up being the top strut hats. So I replaced both strut hats on both front shocks but now I am getting the following suspension codes: U043A-92 and C110C-14. One I see is for the module and other for front left shock solenoid. Now I made sure the plug was installed correctly so I'm thinking it may be a wiring issue? (at least I heard its common on the range rovers for the wiring near the plug to fray apart) Just trying to figure these codes out because the car is unbearable to drive with the Adaptive dynamics fault light on. Much appreciated!
Overkill
Sep 17, 2024 09:43 PM
jaggyedge
Sep 13, 2023 09:24 PM
R3Wood
Jun 29, 2018 09:37 AM
litteredwithfaults
Feb 28, 2018 10:20 AM
Julian Cedrone
Sep 23, 2013 02:41 PM
