Adding a GPS unit
Old Jan 19, 2014 | 05:39 PM
rburnsmd's Avatar
Question Adding a GPS unit
My 2009 XF did not come with a nav unit so I bought a used one on E-bay and connected it to three supplied connectors in the trunk. The GPS unit recieved power but nothing registers on the display. It is also missing the orange wire connector to the GPS unit which I believe may be an antenna wire, but I am not sure as none of the harness wire connectors are labeled on the GPS. Does anyone know if what I need to do to get this Nav unit working.
Thanks in advance.
Old Jan 20, 2014 | 08:03 AM
Jerry S's Avatar
I think you're out of luck. I believe a different body wiring harness was used in the models with a factory installed Nav system making a retrofit of the Nav to the other models impossible.
mrplow58
Sep 30, 2015 08:56 AM
Jaguar Forums Editor
Jaguar Press release
Sep 28, 2015 05:18 PM
jjmiah217
Sep 28, 2015 09:09 AM
42Ajd
Sep 26, 2015 07:04 PM
