Air con + Air vents + heated windscreen + heated seats not working.... Please help!!
Old Nov 27, 2021 | 04:43 PM
W.Dabbas's Avatar
Default Air con + Air vents + heated windscreen + heated seats not working.... Please help!!
Hello all,
I have Jag XF Luxury 2013.
Unfortunately, the air vents are not rotating automatically or blowing air at all, I have tried to check the fuse, but it was alright.
Also, the front/back heated windscreens and heated seats are not working! I don't know if there is something common between them!
I have tried to bypass the pre-heat system (as per here
) underneath the gloves box, but no change. The voltage there was around 14 V, so I'm assuming it is alright till this point!
I am really confused and don't know what needs to be checked
Would you guys advise on what to do please?
Old Nov 29, 2021 | 01:48 AM
kkurulak's Avatar
Sounds like an issue with your ATC (Automatic Temp Control) Module, what came up for a DTC? (Diagnostic Trouble Code) when scanned?
danalpop
Aug 25, 2023 07:33 PM
yellowbandit
Sep 9, 2019 12:55 PM
user 652867429824
Dec 25, 2016 11:32 PM
CadiDrvr
May 25, 2012 10:02 AM
Jeh
XJ40 ( XJ81 )
Feb 2, 2012 04:24 AM
