AJ33s AJ34s differences (Rod Knock)
Old Mar 29, 2025 | 08:27 PM
Rack Jussell's Avatar
Exclamation AJ33s AJ34s differences (Rod Knock)
Hello peeps id like to ask for some help regarding AJ33s and AJ34s differences and if parts can be interchanged.
Car is a 2008 XF SV8 (AJ34s) which has rod knock
Initially i wanted to rebuild the engine but with the damage that probably has been caused to the crank i feel like putting a replacement engine in is the safer way. I would still need to inspect the engine but its quite a job to remove and teardown at this moment so weighing up my options
When speaking to breakers and jaguar parts dealers, its a bit difficult to find AJ34s engines and if found they do go for a very pretty penny. There are a few more 33s to choose from at a lower cost but as you know the ECU in the SV8 is mapped and wired to control VVT solenoids.
my questions are if i go down the route of buying an AJ33s engine could I interchange some parts eg
  1. AJ34s VVT cams and valve covers on the 33s heads
  2. AJ34s complete heads on a short block from a 33s
Iv been reading some of the forum posts similar to this topic and i hear that some sensors throttle body and possibly oil pumps may have been changed for certain MY engines. i will try to use as much as possibly from the previous engine as i can if this swap is even feasible.
Ill also go as far as to say id be happy putting in the whole AJ33s and getting the VVT mapped out but this sounds even more crazy and probably way more work than what if asked above.
im pretty new to the jaguar world and at a loss here so any advice or
criticism is appreciated
Old Mar 30, 2025 | 09:36 PM
xalty's Avatar
33 is the X350 engine
34 is the X103 engine
36 is the DEW98 (S-Type, XF) engine
If you use a 33 or a 36 from before 2006 (i.e non VVT) you're going to have to put on heads and all accessories from your donor motor. 34's have a completely different upper bedplate and go for more money anyways.
Old Mar 31, 2025 | 04:40 AM
Thanks xalty. I didnt know about the AJ36. Great news that i can use my heads. I was hoping for this atleast. ill continue to hunt around
AVRO XJS
May 30, 2024 04:26 AM
rowlands
Dec 18, 2023 02:27 PM
Unhingd
Feb 26, 2019 12:01 AM
muckbury
Nov 3, 2013 09:20 AM
