Auto Windows Up-Down problem
Old Oct 5, 2013 | 10:29 AM
srichhaya's Avatar
Default Auto Windows Up-Down problem
I have a 2010 XF that is just out of warranty, with 41 K miles. I few weeks ago, my 4 year old car battery completely died after sitting in garage for maybe 3-4 days. Anyhow, I got the car jump-started (Took a while using a 4-cylnder car to start an 8-cylinder engine). Mostly everything was fine but I noticed that I could no longer bring up (only) both the front windows by a brief pull on the button. The rear windows were fine.
I tried the training process that was recommended in a different thread, and after a few tries, managed to get the driver window to behave. However, the passenger side refuses to get trained. IN fact, it now does not move up sometimes by either button (driver door button or passenger door button). It does go up after several tries, and maybe getting worse (it started with the first pull not working and then now it is up to 2-3 pulls sometimes before the window will go up)
Any ideas?
Old Oct 5, 2013 | 04:29 PM
JonnyJag's Avatar
What is the condiditon of the battery? Was it replaced? These cars can act funny if there is not full voltage available.
Just to double check your window reset procedure. Make sure you are starting your programming with the window all the way up. Then lift and hold the window switch in the up position for 5-10 seconds. Next lower the window all the way down. release the window switch, then press down for 5-10 seconds. Then test for one touch up feature by lifting the window switch up.
99xk8guy
Sep 29, 2025 10:51 PM
Wolfy
May 28, 2024 08:06 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
pnwrs2000
Sep 3, 2015 11:55 AM
