"Battery No Charging"... But it is.
Old Oct 3, 2023 | 03:34 PM
RA031324's Avatar
Banned
Default "Battery No Charging"... But it is.
I have the "Battery Not Charging" warning on my dash.
I've stuck my multi meter on the battery and it reads what it should when the engine is running or off. So the alternator is doing what it should.
Any ideas?
Old Oct 3, 2023 | 05:44 PM
John Williams's Avatar
What reading do you get when charging?
Old Oct 3, 2023 | 11:40 PM
RA031324's Avatar
Banned
From memory 14.8v whilst running. 12.6v when switch off.
Old Oct 4, 2023 | 06:10 AM
clubairth1's Avatar
Community Influencer
Has the alternator been replaced or is it the factory unit?
Old Oct 4, 2023 | 07:22 AM
RA031324's Avatar
Banned
No idea. Owned it for about 7 months before it happened.
Old Oct 4, 2023 | 07:40 AM
clubairth1's Avatar
OK so it was working fine and you now have the "Battery Not Charging" light? Nothing was touched/replaced?
I wonder if there is a code? Just guessing since it sounds like it's original to the car.
Old Oct 4, 2023 | 08:15 AM
RA031324's Avatar
Banned
No nothing changed. It used to come on every now and then. Then would clear its self.
​But won't go away now.
Old Oct 4, 2023 | 08:29 AM
clubairth1's Avatar
The battery would be the another suspect? How old is it? Do you use a maintainer? As many recommend this if the car is not used daily.
Some cars really go thru batteries and that's a mystery to me?
My 2014 XJR is 10 years old this month and still has the factory battery.
Old Oct 5, 2023 | 12:38 AM
RA031324's Avatar
Banned
It's quite low mileage so I guess that could make sense.
​​I'll have a look though the paper work to see when it was last changed.
RA031324's Avatar
Banned
Also. Thanks for your help. Appreciate it.
Old Oct 5, 2023 | 04:17 AM
Have a read of this, I asked about the charging voltage because if you read the 3rd page, it mentions that if the fuselink fails, the car will go to default charging of 13.7v & the warning light will come on.
​​​​​​https://ibb.co/2sKSSHt
Old Oct 5, 2023 | 06:22 AM
2018XF25T's Avatar
Attach the battery to a charger/maintainer (such as CTek, Battery Tender, Schumacher, Noco. etc) overnight
Old Oct 9, 2023 | 03:31 PM
RA031324's Avatar
Banned
Great thanks. I'll take a look
Terryble
Jan 4, 2023 10:29 AM
nail24fac
Jun 15, 2021 11:10 PM
Per
May 4, 2020 05:53 AM
Jimi Shelter
Feb 19, 2019 11:12 AM
Rhys Morgan
Jan 27, 2018 05:12 PM
