Battery replacement
Old Feb 27, 2015 | 05:19 PM
Dick's Avatar
Default Battery replacement
I have not been driving my 2012 XF much recently (5000 miles past year, 750 miles in the last 5 months). Took it in for oil change today at 22000 miles; when I picked it up they said they noticed it cranked slowly, so tested the battery and replaced it (warranty). Possibly too much time sitting in the garage and not enough time on the highway? Guess I need to get it out more.
Old Feb 27, 2015 | 08:33 PM
Bigg Will's Avatar
Just get yourself a good battery trickle tender/charger. I got one from Sears a few years back for $20, I plug it up to my XFR when I know its going to be down more than 2 days. It even came with the connectors needed for permanent battery direct plug in.
Old Feb 27, 2015 | 08:51 PM
XJL's Avatar
XJL
I had similar issues until I got a pair of trickle chargers. I put them on once or twice a week overnight.
Old Mar 15, 2015 | 07:50 PM
Dick's Avatar
Thanks for the advice, guys.
Do you hook through the accessory port (cigarette lighter), quick disconnect at the battery, alligator clips, or ?.
Old Mar 16, 2015 | 11:06 AM
Long Islander's Avatar
Cig lighter power goes dead after 10 minutes on mine (2010), so I installed a quick connect to the battery and extended it to the small fuse compartment on the right side of the trunk. All I have to do is remove the small access cover and pull out the quick disconnect and I can connect the battery maintainer.
Old Mar 17, 2015 | 08:43 PM
Dick's Avatar
Heck, forgot about the time limit on the electronics. I guess nothing is "easy".
Old Mar 20, 2015 | 03:31 PM
neogod's Avatar
Or, if you are going to not drive it for a long period of time, you could always disconnect the battery.
Old Mar 23, 2015 | 06:21 PM
hlgeorge's Avatar
I would not recommend that simply because you may have to reset all the electronics when you reconnect the battery.
Old Mar 25, 2015 | 10:19 AM
XJL's Avatar
XJL
I use the quick connects from the battery. Literally takes less than 30 seconds. I leave the trunk partially open.
Old Mar 25, 2015 | 06:10 PM
hlgeorge's Avatar
I close the trunk. Plenty of cushion in the seal.
JarodL
Mar 7, 2024 01:39 AM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
obwoodie
Sep 3, 2015 07:45 PM
OkieTim
Sep 2, 2015 12:48 PM
