Big xenon questions
Old Jun 12, 2017 | 01:05 PM
cyndav6875's Avatar
Default Big xenon questions
I was wondering if there is a brighter bulb upgrade for my 09 xf scheduled? I think it is ds1? Not looking for too much color change just brighter? Less or more lumens I think? Any advice would help and be appreciated.
Old Jun 12, 2017 | 02:12 PM
VPinGA's Avatar
You may want to look at the D1S: Osram Xenarc 66140 CBI. I have used the CBI's on several cars now with good results. Brighter than standard hid's, less yellowish tint than standard, and quality factory made.
https://www.osram.com/osram_com/prod...ense/index.jsp
Old Jun 12, 2017 | 06:06 PM
OzXFR's Avatar
The link above is to the D2S, which won't work in an XF, you need the D1S (66144, not 66140) for an 09 model and the D3S for a MY 2012 onward.
I swapped out the stock bulbs on my XFR to 6000k cheapish Chinese ones (not CBI) and they worked well.
I also recently changed the bulbs on my F-Type to Osram Zenarc D3S CBI 5000k and I'm very happy with them, nice strong bright white light much better than stock.
Old Jun 13, 2017 | 07:01 AM
VPinGA's Avatar
Hi. The link was pointing to the Osram website, it lists all the flavors. Actually, at least here in the US, i can assure you the 66140CBI is the cool blue D1S bulb. (see attached spec sheet). I am not familiar with the 66144 you mention, but i see on the osram site they list it as D1S CBH, cool blue hyper xenarc, which has a slightly more blue, higher kelvin temp. Maybe it's a newer version, don't know. I haven't used those before, but they do look like a good choice for the future.
But at any rate, I only wanted to point out that the Osram D1S cool blue bulbs work well and are good quality.
File Type: pdf
