Bunch of codes after replacing my rear pads??? - RESOLVED
Old Nov 8, 2018 | 12:27 AM
blown Jag's Avatar
Default Bunch of codes after replacing my rear pads??? - RESOLVED
WTH
I replaced my rear pads yesterday on my 2010 Jaguar XFR and since then I am getting a bunch of codes appearing in my center dash. I replaced the sensor for the low pad warning on the passenger side but I am always getting a code for my left rear wheel speed sensor. I didn’t even touch it. I cleared the codes a million times, unplugged my battery 3 times, removed the left rear wheel speed sensor and cleaned it. Still all there abs, dynamic mode, traction control, E-Diff faults are always showing up. Did this ever happen to anybody else, and if it did , what was the solution to fix this problem.
thanks a head of time for the help.
Marco
Last edited by GGG; Nov 15, 2018 at 01:31 PM. Reason: Add "RESOLVED" to thread title
Old Nov 8, 2018 | 02:49 AM
Originally Posted by blown Jag
...... I am getting a bunch of codes appearing in my center dash. .....
I've moved your question from X260 (2015 onwards) to X250 (2007 - 2015) forum. This is the place to post technical questions about your 2010 model.
Codes in the centre dash. Do you mean warnings in the Message Centre or have you had a scantool on it to read error codes?
On other Jaguar models which show similar fault combinations (e.g. X100), it is often found to be a wheel speed sensor link harness and not the sensor itself.
Old Nov 8, 2018 | 05:00 AM
blown Jag's Avatar
Yes warnings in the message Center. Traction control, abs fault, dynamic fault, E-Diff fault. Abs light and dls light and engine service light stay on the dash, even on ignition without car running. Put my scan tool on it and it gave me this:
C003A Generic
left rear wheel speed sensor supply
(sub fault)
Old Nov 13, 2018 | 11:41 PM
2010 Kyanite XFR's Avatar
I've had that after dyno runs, but you obviously haven't done one. How far have you driven after first seeing the messages? After dyno, I needed to drive 15-20 miles before they would go off.
Old Nov 14, 2018 | 08:53 PM
lotusespritse's Avatar
Sounds like you got a little rough during the brake pad change and probably damaged the connection for the speed sensor without knowing it.
Old Nov 15, 2018 | 12:48 PM
blown Jag's Avatar
Everything is good now. Found out what happened. When I was changing the brake pad wear sensor on the rear , right side. I had unplugged the rear right wheel speed sensor by accident instead of the brake pad wear sensor. I had plugged it back in but not deep enough for the connecter to clip. When I pushed it in all the way and clipped, all the problems went away. Thank god, was an easy fix. What threw me off was the fact that my scanner was telling me that it was my left rear wheel sensor that was giving me a problem. Didn’t touch anything on that side except for the replacement of the pads. Anyways, long story short, everything works well now.
Old Nov 15, 2018 | 01:33 PM
Thanks for posting the successful resolution. I've added "RESOLVED" to your thread title.
Old Nov 16, 2018 | 10:05 PM
I was close...
scardini1
Sep 17, 2016 11:45 AM
jagcfp
Sep 22, 2014 12:46 PM
jagcfp
Sep 11, 2014 08:29 PM
rsamples
Jul 12, 2011 02:06 PM
SEBZX79
Jan 7, 2011 06:28 AM
