camshaft position sensor identification
Old Mar 7, 2021 | 03:19 PM
superv803's Avatar
Default camshaft position sensor identification
2010 XF 5L naturally aspirated. Had two P0018 codes over a month, first time also had P0016. Both times after just leaving partially heated garage., Very short warm up. February, cold in Canada.Battery is good. Went away after brief "restricted performance" message and car runs fine.My son's OBD readout says bank 2 sensor A. I have a new sensor to install. I have spent hours pereusing these different threads, but I am still not sure which sensor to target. I think it is one of the driver side front sensors, nasty place to get at. Clarification appreciated!!
Old Jul 8, 2021 | 11:24 PM
adrenaline's Avatar
Anyone have any ideas?
Old Jul 9, 2021 | 01:02 PM
kansanbrit's Avatar
Bank 2 sensor A is the intake camshaft sensor on the driver's side. The top one of the two. A single Torx screw. Pull of the air intake tubing, should be easy access then.
Old Jul 9, 2021 | 05:23 PM
adrenaline's Avatar
there appears to be a bunch of lines/tubing in front of it after taking off the intake though.
Old Jul 15, 2021 | 12:40 PM
superv803's Avatar
Thank you for that input.
Old Feb 12, 2022 | 01:26 PM
Herbert's Avatar
Hello, Let me introduce myself,
my name is Herbert and I live in the Netherlands.
My car is a 2009 Jaguar XF 4.2 supercharged
Can someone post a picture of the sensor position?
I can not find him
Thanks.
Old Feb 13, 2022 | 10:21 AM
clubairth1's Avatar
Community Influencer
Please start another thread as your problem concerns the older 4.2L V-8. He has the later 5.0L V-8 which is a completely different engine.
When you start your thread post any error codes you can get from the car as that will help guide us to where your problem is.
scottatl
Mar 9, 2021 06:07 PM
JagDE45
Sep 5, 2018 08:57 AM
Peperami
Mar 25, 2015 04:35 PM
StevenUSAnh
Nov 23, 2013 11:21 AM
Idrivejags
Dec 1, 2008 07:26 PM
