Car goes in for a few issues tomorrow....surprised by one item
Old Jun 11, 2012 | 07:11 PM
cwood's Avatar
Default Car goes in for a few issues tomorrow....surprised by one item
Sunroof started creaking over the past month. I know its a common thing so called to have it looked at.
I had also noticed that the driver door must be sagging a tiny bit as the chrome trim above the window is contacting the trim above the rear door. The door looks perfectly aligned but its off just enough that there is a tiny contact and it has actually taken a chunk out of the rear trim. I asked them to fix this as well and the service advisor said it would be chargeable! After a year its not covered. Car has never seen anything other than normal use...no accident etc. Brutal. If it were trim falling off inside it would be covered no doubt. This major component issue not being covered blew me away. Perhaps I am supposed to stay in the car and climb out of the sunroof?
Old Jun 11, 2012 | 07:51 PM
CP1's Avatar
CP1
This should be covered by the normal 5/50000 warranty.
Old Jun 12, 2012 | 12:16 PM
cwood's Avatar
Initial update from dealer (they picked up the car this morning at my office) is that it is all covered and they are sending it to the body shop for adjustment and will replace the trim sections as well! They are also bringing a loaner for me as it won't be back today. Impressed so far.
Old Jun 12, 2012 | 01:21 PM
arlingtonman's Avatar
Wow - sounds like a good dealership!
Old Jun 12, 2012 | 07:09 PM
darlo's Avatar
I had exactly the same problem with the door and rear trim. Fixed and replaced under warranty - glad you got the same result in the end!
Rupesh
Mar 25, 2016 03:33 PM
NorJag
E type ( XK-E )
Aug 28, 2015 07:31 AM
Goncalo Proenca
Aug 27, 2015 03:55 PM
Terencex
Aug 26, 2015 08:47 AM
NinoGrimace
Aug 26, 2015 05:15 AM
