Climate Control
Old Dec 19, 2008 | 08:09 PM
jagular's Avatar
Default Climate Control
In minus 20C and colder weather my XF pumps out way too much heat to the front footwells on the"Auto" setting. Has anyone else experienced this. I have a lot of expereince with automatic climate control in my other cars and those systems work very well, except for my Alfa Romeo which has the cabin air sensor in the roof and doesn't work well. My Audi and my SAABs both work perfectly and the X Type worked very well except it was a bit chilly on occasion.
It seems odd to be complaining about too much heat in the extreme cold, especially from a British car, but it is unacceptable in this day and age to have defective climate control.
Old Dec 19, 2008 | 08:17 PM
Brutal's Avatar
Default RE: Climate Control
Well we dont deal with that issue much in Houston, But the footwell discharge is ALWAYS friggen too hot for me, its the closest to the heater core, and hard to overcome physics, I turn off the foot or turn the temp down. Cause after awhile it does get hot
Old Dec 20, 2008 | 02:47 PM
jagular's Avatar
Jaguar uses an air blend system which should deliver cold air to the footwells when required even though the heater core is right there. The heater core is a full flow design and air temperature is supposed to be controlled by mixing unheated (or air conditioned air in the summer season) with the correct amount of heated air from 0 to 100% to achieve the correct temperature.
My XF seems incapable of doing this when the outside air gets too cold.
Old Feb 24, 2009 | 07:15 PM
jagular's Avatar
Any Canadian owners (or cold climate owners) notice this phenomenon? At temperatures below about minus 5C the footwell heat is way too hot. My mechanic measured the difference between the footwell temp and the fac level vent temp at 50C (that's the difference! not the actual temp) with the climate set at 20.5 C.
3lvis
Oct 1, 2015 01:56 PM
leep123
Sep 30, 2015 03:41 PM
mrplow58
Sep 30, 2015 08:56 AM
zdrapec
Sep 25, 2015 05:49 AM
