Code p0174
Old Feb 7, 2014 | 07:16 AM
jaguarxfv8's Avatar
Default Code p0174
Hi, my jaguar throw me this code out of nowhere p0174 system run poorly group 2 !
What the hell does it mean ?
How can I fix it ?
Old Feb 7, 2014 | 08:08 AM
BritCars's Avatar
Here is a thread with some ideas on this - sounds like it is a well explored issue on the S-Types so may give you some ideas for yours. Also a description of what the code stands for:
https://www.jaguarforums.com/forum/s-type-s-type-r-supercharged-v8-15/p0171-p0174-52450/
P0174
Engine misfire
Air intake leak between MAF Sensor and
cylinder head
Fuel filter / system restriction
Fuel injector restriction
IP Sensor fault (low fuel pressure)
Low fuel pump output
HO2 Sensor(s) (2/1, 2/2)
harness wiring condition fault
EFT Sensor fault (low fuel temperature)
MAF Sensor fault (low intake air flow)
Exhaust leak (before catalyst)
ECM receiving incorrect signal from one or
more of the following components:
ECT Sensor, MAF Sensor, IAT Sensor,
IP Sensor, EFT Sensor, TP Sensor
And some info on here too:
P0174 Jaguar System Too Lean Bank 2 OBDII Engine Light Trouble Code | Engine-Codes.com
What model and age do you have? Still under warranty? If you don't know what it is, I'd suggest taking it in to resolve.
Good luck!
Old Feb 9, 2014 | 05:50 PM
jaguarxfv8's Avatar
Default thanks
P0174
Engine misfire
cylinder head
Good luck!
thank for this that's some information I already had, but now I check my sensors but I'm wondering I just change the spike plugs and it took me a long time to change them and they were really really dead and I think some gas got into my oil cause, my oil smell like gas so …. I don't know lol
Old Feb 22, 2014 | 11:03 AM
jagular's Avatar
Why did you replace the spark plugs? They are iridium tipped and the service life is 160,000km.
Did you replace them with the correct plugs?
clubairth1
30
Sep 3, 2025 04:38 PM
bdboyle
Sep 16, 2019 05:58 PM
JCam
Oct 23, 2016 08:27 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
