Coolant Leak
Old Mar 12, 2022 | 02:35 AM
Liam C's Avatar
Default Coolant Leak
Hello all,
Car Details:
Jaguar X250 2008 PLATE - 2.7 DIESEL.
Since November 2021, I've noticed that my coolant levels are dropping - Nothing on Dash to indicate overheating or low coolant. Luckily I found it before that. - I've been topping it up with water etc now until I can get it to a garage. Rougly when topping this coolant up it lasts 1-2 weeks before topping again - When i Top the coolant up - I only top it up with half a kettle full.
The car runs fine - No loss of power.
These are the checks I have done.
Checked oil - Fine
Checked Oil Cap - Fine
No Smoke coming out of exhaust.
I'm only seeing these leaks when I'm parked at work - rarely see them outside my house. Now, yesterday I noticed (which I think) was a smell quite Strong/Sweet from my exhaust. Now after doing research people are saying 'HeadGasket'
It's finally booked in now on monday -I'm just looking to see if anyone has experienced this before.
Old Mar 12, 2022 | 05:47 PM
BritCars's Avatar
Looks like it's leaking coolant at the front. Most likely one of the many plastic pipes or water pump. Which age and go brittle. Possible a head gasket although not a common issue on these cars
You're right to have it checked into. Any coolant leak can lead to overheating and very expensive or irreparable damage. I wouldn't drive it around until it's fixed
Old Mar 13, 2022 | 03:17 AM
John Williams's Avatar
Liam, Your posting on a US based site, that never had the engine that you are asking about!
I have given you advice on another UK site, so not much point asking on here
justacarguy1998
Nov 7, 2021 06:54 PM
stran0020
XJ40 ( XJ81 )
26
Jun 5, 2021 01:12 PM
Latjag-lv
Aug 19, 2017 07:46 PM
Ken2839
Oct 3, 2016 09:42 PM
jmcGoBlue
Mar 5, 2012 11:41 AM
