Cruise Control Failure on XF
Old Dec 21, 2009 | 11:56 PM
davidcalgary's Avatar
Default Cruise Control Failure on XF
I'm having repeated problems with the cruise control on my XF Supercharged. It will repeatedly kick out with different errors
  • Radar sensor blocked (checked and cleaned the front sensors - didn't help).
  • Driver Intervene.
I usually drive with Dynamic setting on and the `DSC' light is on in that case. On a recent long-distance run, the cruise would drop out again and the DSC light would go out although it would remain in Dynamic mode. That was different behaviour than I have seen before.
Has anyone had any similar experiences?
Old Dec 22, 2009 | 12:36 PM
jagular's Avatar
Default Cruide will cut out whenever the DSC is active
This is a safety feature. You may not be aware of any wheelspin but if the DSC detects any at all then it cuts out the cruise. If you ever use cruise in winter (bad idea BTW) you would fully understand why this feature is included.
This may not be your issue but it is worth being particularly observant whenever the cruise kicks out and see if you can feel any wheelspin at all.
If you really are from Calgary as your name suggests then this is your answer if you have tried to use cruise at all recently. I am from Calgary and I stop using cruise control when the roads get cold. It isn't safe to use cruise in winter conditions.
Old Dec 23, 2009 | 09:29 AM
PilotRPI's Avatar
Althought not in a Jag, I've had CC disable itself even if I go over a hard bump or rise in the road, as it causes enough variation in wheel speeds to make the car think it is losing traction.
Old Dec 23, 2009 | 03:38 PM
I finally spoke to someone at the dealer who had taken the time to research this subject and could give me an informed answer.
Apparently, the cruise setting needs to be re-callibrated when the wheel sizes change (makes sense). I suspect mine was never callibrated correctly and so the CC kept kicking out in otherwise normal conditions. She also noted that the cruise should not work below -5C.
Thanks to the folks who responded.
Old Dec 28, 2009 | 02:13 PM
jagular's Avatar
Cruise on my car works down to at least minus 12C (it didn't get any colder than that when I tried it). I doubt that it is temperature sensor connected. It certainly is unwise to use cruise control in freezing weather if there is any risk of ice at all. Similar considerations apply to using cruise in rainy weather.
Johnken
Sep 22, 2015 03:53 PM
mrobinson
Sep 18, 2015 07:20 AM
Skeeter
Sep 17, 2015 08:15 PM
Donzi
Sep 17, 2015 01:29 PM
XFR_Gold
Sep 2, 2015 12:24 PM
