Cruise not available
i have a 2009 jaguar xf. This morning i started up the car as usual but to realise that there is a "Cruise not available" warning light on and it disappears after a few seconds. Can someone help me with this problem that im facing ?? Its quite urgent. Thanks for your help!
Welcome to the forum Alronong,
+1 on the battery.
I've deleted your duplicate post from X-Type forum.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
+1 on the battery.
First check the battery but with a LOAD TESTER. I've seen many batteries pass the conductance test (I call it wimpy test) but not the load test. If the battery is good then I would go for the brake switch. Personally I would read fault codes but not everybody has the factory Jag tool. Brake switches go bad all the time...
FS[NorthEast]: 2008 XJ Super V8 - Black on Cream
sg997tt
Oct 9, 2015 10:57 PM
