Dashboard speaker grille.
Old Oct 1, 2014 | 02:53 PM
Triplex32's Avatar
Default Dashboard speaker grille.
I was wonder if anyone on here knows or has replaced the speaker cover/grill on the dashboard. If so would will I have to remove the whole dash in other to install or that the grill just pop off? Been looking online like crazy and no luck with info on this yet. So any info would help please and thank you..
Old Oct 2, 2014 | 06:13 AM
philhef's Avatar
Mine was cracked when I bought it and they had to replace the whole dash. Also had some leather lifting. They said it was pre installed in the dash.
Old Oct 2, 2014 | 11:40 AM
sir2's Avatar
it'll pop right off, but if your original center speaker grill is cracked, It's got to be cracked for a reason. I'd suggest repairing whats causing it to crack first before replacing the center grill
Old Oct 2, 2014 | 12:54 PM
I was wonder if anyone on here knows or has replaced the speaker cover/grill on the dashboard. .......
Welcome to the forum Triplex32,
Available as a separate part, the Speaker Grille appears to be fitted with the standard Jaguar arrangement of spring clips which can be released by carefully inserting a plastic or wooden tool under the lip of the grille and prizing it up.
Note there's 4 colour options, 3 badge options and the Part Number changes 3 times across the VIN range!
Presence
Mar 13, 2016 02:21 PM
magmedia
Oct 8, 2015 03:28 PM
Fletch44
Sep 28, 2015 02:21 PM
pino
Sep 26, 2015 08:05 PM
